SMB2 Support (W7/2008/Vista)
StefanDidak
Post by StefanDidak »
It would be nice to have a choice (option/preferences) about which file copy API is used for file copies in Salamander combined with support for SMB2 (W7/Vista/2008). The reason for this feature request is because, right now, if I copy files over the network using Salamander I often have to start two simultaneous copies to get the full gigabit bandwidth to be used. The current file copy performance on a gigabit network (with jumbo frames enabled) that I am seeing is 60-80MB/s. Not bad but when I use the Windows Explorer between systems running W7/2008/Vista it really maxes out the bandwidth at 100-110MB/s.
So the feature request is for two separate things, 1) SMB2 support and 2) a preferences option to decide which copy method is used.
Stefan
Yes, the not-working-for-NASA or NSA incredibly-insane-Home-Office guy!
Re: SMB2 Support (W7/2008/Vista)
FYI (For My Information ;-)), (Windows Vista networking technologies) Server Message Block 2.0.
