Dear Sir
I have sent seven bug reports on the subject, but there is no response from you or any corrective measure.
I am a licensed user of your product.
Kind Regards
rcgoyal@avrms.com
Bug Report each time I start Salamandar 2.52
- repeatederrormessageseachtimeiopensalamandar2_52i.zip
- Pepeated error message
- (16.94 KiB) Downloaded 857 times
Re: Bug Report each time I start Salamandar 2.52
We are sorry for delayed answer. The problem is in following faulty shell extension:
C:\Program Files\Norton 360 Premier Edition\Engine\3.0.0.135\buShell.dll
Unfortunately there is nothing we can do, it must be fixed by Symantec. Do you have latest version of Norton 360?
Thread ID: 0x7FDC (Thread with Exception)
EIP = 0x78138AA0 MSVCR80.dll
0x6F185E1B buShell.dll
0x004450EC salamand.exe
0x00445230 salamand.exe
0x0044529D salamand.exe
0x23907AF9 SALRTL.DLL
0x7C80B729 kernel32.dll
Yes, Resavy
I have the latest Norton 360
Please inform me how to help myself. I am not a developer.
Regards
rcgoyal@avrms.com
Regards
rcgoyal@avrms.com
[quote="rcgoyal"
[/quote]
It's a Symantec problem
[/quote]
Hello rcgoyal,
delete the "salamand.bug" file in the installations folder of AS 2.52 (or move this file to an other folder e.g. Bugs)
I hope, I understand your issue correctly and I could help you.
(I know nothing of Norton 360...)
Appears that buShell.dll a "Backup Shell extension" (whatever that may be).
Per this (dated at this point) article, Norton 360 zombie processes, buShell.dll "provides the following extra features that are not vital for the Backup component to work":
Instead of manually unregistering it, you might find this little utility a bit easier to use, Nirsoft: ShellExView - Shell Extensions Manager.
So if this is not of significance to you, it would seem you could disable (unregister) the dll without consequence.1. Icon overlays, these are little indicators that show the state of the files that are backed up, by default they are not turned on so you would not see them unless you specifically turned on "Backup Status Indicators" in the Settings page.
2. The ability to right click a specific file or folder and see the quick menu to allow you to add or exclude that item from the backup set.
If your system becomes unstable AND your installed Norton 360 then the problem seemed the be the buShell.dll
To unregister the buShell.dll, which is normally saved under C:\Programme\Norton 360\Engine\3.5.2.11\buShell.dll
please follow these steps:
1) Start windows under "silent mode", otherwise the buShell.dll cannot be unregistered. Press <F5> during boot procedure.
2) Start a command shell, select start menu / Run... / type "cmd" without the quotes
3) Next you will change directories to type cd "\Program Files\Norton 360\Engine\3.5.2.11" with the quotes
4) Then you will unregister the dll, type regsvr32 /u buShell.dll
5) A dialog should be shown with the following text : "DllUnregisterServer in buShell.dll succeeded."
6) Now close windows in the silent mode and start windows again in normal mode, now Salamander should run proper as usual.
Or easier...
Download ShellExView from Nirsoft, look for the named shell extension, select it, click the red button to disable the extension and reboot.
GEORGE STAFFA
Salamander will offer the solution itself. It requires no expertise. Do not delete the bug file. Start and exit Salamander repeatedly until you get an error dialogue offering several options including "yes" and "all". (I do not remember the content of the dialogue.) Press "all". You may now delete the bug file and close Salamander. Start Task Manager, select the processes tab, and delete all instances of salamander. The bug should never appear again unless you must reinstall or reactivate Salamander.
GEORGE STAFFA
GEORGE STAFFA
@GEORGE STAFFA, what OS are you running? Guessing it is Vista or W7 & it is the OS itself which after finding Salamander crash, is setting up some sort of "compatibility" mode to run it under thereafter.
