Access to Pocket-PC using ActiveSync
Posted: 13 Dec 2005, 20:20
by tdrees
as far as I remember, there was a possibilty to access the file-system of a pocket-pc when ActiveSync is installed. There was a shortcut to it in the "Change Drive" dialog. In the most current beta this shortcut is no longer there. Is this feature discontinued?
Regards,
Torsten
Re: Access to Pocket-PC using ActiveSync
Posted: 13 Dec 2005, 20:49
by ino
tdrees wrote:Hi,
I guess you can select which plugins are accessable from "Change Drive" dialog.
Point to Menu - Plugins - Plugins Manager. There find/focus plugin you are reqested and check the down-left checkbox "Show xy item in Change Drive menu".
Posted: 13 Dec 2005, 23:45
The Windows Mobile plugin detects the presence of ActiveSync software during Servant Salamander installation and hides its Change Drive menu item if ActiveSync is not found.
If you install the ActiveSync after Servant Salamander, you must explicitly enable this menu item as mentioned ino.
Posted: 14 Dec 2005, 07:49
by Guest
Thanks guys!
Posted: 31 Dec 2005, 13:37
by daern
It's worth noting that the Windows Mobile plugin doesn't yet work with WM5 devices (i.e. new ones)...
Posted: 02 Jan 2006, 22:36
daern wrote:It's worth noting that the Windows Mobile plugin doesn't yet work with WM5 devices (i.e. new ones)...
Please look at
http://forum.altap.cz/viewtopic.php?t=106
