as far as I remember, there was a possibilty to access the file-system of a pocket-pc when ActiveSync is installed. There was a shortcut to it in the "Change Drive" dialog. In the most current beta this shortcut is no longer there. Is this feature discontinued?
Regards,
Torsten
Access to Pocket-PC using ActiveSync
Re: Access to Pocket-PC using ActiveSync
Hi,tdrees wrote:Hi,
I guess you can select which plugins are accessable from "Change Drive" dialog.
Please look at http://forum.altap.cz/viewtopic.php?t=106daern wrote:It's worth noting that the Windows Mobile plugin doesn't yet work with WM5 devices (i.e. new ones)...
