Salamander 2.52 and TortoiseCVS 1.10.1 unstable
Tipperton
Post by Tipperton »
This new version of Salamander and Tortoise CVS don’t seem to get along at all, I’m receiving constant instability reports from Salamander.
Tortoise is the latest stable release (v1.10.1)
CVS client version: Concurrent Versions System (CVSNT) 2.5.03 (Scorpio) Build 2382
SSH client version: TortoisePlink: Release 0.60
For now I'm going back to v2.51 it at least didn't have problems with Tortoise!
EDIT by Jan Rysavy: bug report removed.
Note: Please do not post crash reports here, send us the generated bug report by email instead. Thank you.
Re: Salamander 2.52 and Tortoise CVS 1.10.1 unstable
Thank you for this information. Did you try the development build of TortoiseCVS?
There was same problem in TortoiseSVN for several months, please look at http://forum.altap.cz/viewtopic.php?f=2&t=2575
There is a 99% probability that problem is on TortoiseCVS side.
Tipperton
Post by Tipperton »
Jan Rysavy wrote:EDIT by Jan Rysavy: bug report removed.
You should note that on your web site, all it says is that this forum is the official means of support so one would conclude that crash reports should go here as well.
Jan Rysavy wrote:There is a 99% probability that problem is on TortoiseCVS side.
I'll try it but as a general rule I try to avoid beta or "for testing" software in a production environment.
Tipperton wrote:You should note that on your web site, all it says is that this forum is the official means of support so one would conclude that crash reports should go here as well.
The Bug Report dialog (from which you got the bug report) itself says that you should send it using email.
Re: Salamander 2.52 and TortoiseCVS 1.10.1 unstable
See the main forum page.
Do not post crash reports here, send us the generated bug report by email instead, please.
Regarding TCVS: try to contact TortoiseCVS developers and show them the same problem in TortoiseSVN.
