Shell Link Viewer Plugin
stepand76
Post by stepand76 »
Shell Link Viewer is plugin for view information on Windows shortcuts.
Plugin is available here:
http://sites.google.com/site/stepand76/asplugins-enu
You can discuss the plugin in this thread.
Any comments, suggestions and feature requests are welcome.
stepand76
Re: Shell Link Viewer Plugin
Post by stepand76 »
Version 0.5.0 (23.10.2009)
[+] Added the "Focus" command (F) - focuses the file in the panel.
[+] New keyboard shortcuts (Ctrl+F, Ctrl+T) assigned to the "Go to Target" command.
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancement
th.
Post by th. »
I've been downloading the shelllinkviewer_0.5.0.399.zip from your site, but when installed it says Version 0.4.0?
Furthermore, there are 2 items labeled "Start in" whereas the second of them should be "Comment" I guess.
stepand76
Post by stepand76 »
Thank you. I will look at it.
stepand76
Post by stepand76 »
Fixed (will be available next week).
stepand76
Post by stepand76 »
Version 0.6.0 (25.2.2010)
[*] Built with Delphi 2010.
[+] Enhanced "About" window.
[+] Added an option to save possion and size of viewer's windows.
[+] Added an option to prefer keyboard shortcuts in main menu.
[+] Added a command to execute the target file.
[-] Fixed version number in the About window.
[-] Fixed labels in viewer.
Legend
[*] Change
[-] Bugfix
shelllinkviewer_0.6.0.zip
(701.52 KiB) Downloaded 1101 times
