[Usermenu] Powershell Script with $(ListOfSelectedFullNames)
ThomasL
Post by ThomasL » 10 May 2017, 13:32
Hello,
can anybody tell me which calling syntax I must use in the usermenu that Powershell (4.0) recognizes each passed quoted filename as a script parameter while using $(ListOfSelectedFullNames)? I cannot get it to work.
Re: [Usermenu] Powershell Script with $(ListOfSelectedFullNames)
Post by tukanos » 22 May 2017, 09:55
I would gladly help you, but you need to share more information, best with screenshots.
What are you calling? You are calling .ps1 script or batch file which is calling a script? Are you calling as normal user or administrator?
What errror messages you get?
How are you calling it from Altap Salamander? (description and screenshots would be best.)
ThomasL
Post by ThomasL » 22 May 2017, 10:31
Thank you for your help but In the meantime I figured it out on my own.
The use of the param() keyword in the script was kind of problematic. If I have it in the script I wasn't able to address each selected filename (path and filename with spaces) as a single parameter. After I left it out I can simply loop through the default $args array and use its elements as (file-)parameters.
