Hi!
When using altap 3.08 (and older) both x86 and 64 startd as administrator or not the following issues has been noted:
# Pin to start is visible but not working
# Pin to taskbar not visible.
This means that i have to find the stuff in explorer and pin it from there.
This is a little frustrating.
Help is appreciated.
/Patrik
						Altap 3.08 and windows 10 "pin to ..." not working
Re: Altap 3.08 and windows 10 "pin to ..." not working
Pin to start does work for me (from Start menu).
Pin to taskbar is available from Taskbar context menu.
