AS cannot see network but network OK
GregH
Post by GregH »
I'm running AS 3.08 x64 with Win7 x64
AS just reports "(67) The network name cannot be found" when trying to access the network via the icon.
If I use MS Explorer (Winkey+E) it sees all the network OK and I can connect eveywhere OK.
Also if I make a Hot Path button, I can navigate to the network OK and set a path that connects OK.
I have this same problem on two machines.
Any ideas why the network icon cannot see the network properly? I have tried turning off firewall etc.
thanks
Greg
Re: AS cannot see network but network OK
You did not say how you access the network resources. Do you want to access it via \\server\share or do you have a mapped network drive? Like Z:\?
Are you running Salamander in elevated mode? (As administrator) You have to be a bit more specific.
Describe the network.
