Forward slashes a path separator
Forward slashes '/' have always been accepted by the Windows kernel. I don't know how widely it is supported, but generally it works just fine. (On the command line you usually need to quote a path containing forward slashes, and are dependent on how the called program interprets it's parameters.)
Here the first link I found related to the topic: When did Windows start accepting forward slash as a path separator?
And here is another good read about it's background: Why is the DOS path character "\"?
Salamander seems to partially accept it. I just copied such a path from a config file into Salamander's (2.54) Search window:
C:/Users/Me/Document/ resulted in a search result containing C:/Users/Me/Document/\Folder\File.ext (Note the rather uggly but otherwise functionally fine /\ part.)
The internal viewer refuses to show the file, so does Focus
With the trailing slash removed from the "Search in" box Focus works
With the first slash removed (i.e. C:\Us...) the internal viewer works
Could Salamander please handle these, and similar cases, either by supporting '/' throughout, or by transforming all path from outside of it (UI, text files, command line, ...) to the canonical format.
Re: Forward slashes a path separator
Thanks for reporting this bug. I'll fix it. I'll also try to find other places where Salamander is not working well with slashes in paths.
mhaeusser
Post by mhaeusser »
It would also be great if paths that are copied into the clipboard (Alt+Insert) used forward slashes.
I have lost so much time converting the backward slashes into forward ones.
Not a good idea. It's windows, not linux. forward slash is used in command line as a switch for parameters.
Backslash is used as a escape character. i.e. \r\n for cariage return / new line.
Anyway, the further development of Salamander is halted for the time being.
