Transfer Problem with Plugin WinSCP
oliver
Post by oliver »
Hi all,
i got a problem with the WinSCP Plugin, which I wanted to use for transferring files from one linux-server to another, both remotely.
I do open left and right pane,both with WinSCP Plugin - that works well.
Then, when I press F5 on any file of any pane the following message will pop up:
Plugin cannot work with path 'scp://root@xx.xx.xx.xx/data'.
What I am doing wrong? Transferring files via command line works with scp. Maybe a missing cert or something?
Thank you very much in advance.
Oliver
Re: Transfer Problem with Plugin WinSCP
I am not absolutely sure, but I believe that "FXP" between 2 SCP connections is nor supported by the plug-in.
I believe that this questions has been already answered in the forum. Just search.
Yes, unfortunately such operation is not supported.
oliver
Post by oliver »
thank you for answers.
FXP needs also special settings on the two servers, I tried that before and gave up.
But I actually do not use FXP, but SCP, that's just like a cp, but secured (like SSL, or HTTPS for web).
Anyway thanks, I will search the forum again.
