application stops responding and gives no info
jwatersphd
Post by jwatersphd »
in windows 10, servant salamander just freezes, and cannot be closed by most normal means, i.e., task manager or checking the Resource Monitor's wait chain. it's not even listed, in computer management, as a service. I've tried to reinstall it from a downloaded file, e.g., as307x64, but eventually it still hangs and refuses to even be terminated. I am wondering if I have to eliminate it from the registry by hand, or use some other drastic uninstall procedure, and then reinstall it. It's a great program, but it's really fallen apart on my machine, a dell inspiron. When I go to computer management for event viewer, there is no mention of anything occurring with it, either.
Re: application stops responding and gives no info
A bad shell extensions is In most cases the cause of a freeze. Have you recently installed an app which adds "features" to the context menu?
P.S.> Salamander is not a service, its a app.
jwatersphd
Not that I know of.
Then start a new instance of AS, go to Help > Task list, select the frozen instance, hit the [Break] button and follow instructions.
A report will be sent to the Altap team where they can analyze it.
