How do I run the List Command?
dea5306
Post by dea5306 »
I was wondering how I would Run the List command to Export a file that servant salamander creates into Excel where my list of images would display in cells running vertically. If anyone could help me with this I would greatly appreciate it.
Re: How do I run the List Command?
easy...
- select files you want to create the list of
- CTRL+M
- in the dialog enter: $(FileName)$(CRLF)
- select Clipboard
- click OK
- open Excel, go to cell A1
- CTRL+V
- save file
