Renamer plugin greyed out
Deadly
Post by Deadly »
After I selecting a directory (or file), I scroll down the Plugins list to run the Renamer...but the entry that pops up to the right (Batch Rename... Ctrl_Shft+R) is greyed out. I've gone to the Plugins manager, and it says it is loaded...and when I select "test", it says it is working.
What am I doing wrong?
EDIT: I reinstalled...and all is well. Not sure what the problem was, but all functions are working again.
Re: Renamer plugin greyed out
Could you please post your Product ID? See Help > About Altap Salamander.
It seems there is some problem with your license.
EvaEden~
Post by EvaEden~ »
I'd the same problem with some plugins when a 'registry repair' tool has deleted some registry entries of AS. After inserting the saved config_.reg all was ok.
Hope this helps.
Regards
Eva~
