Right clicking (while files selected) should offer Pack/Unp
John
Post by John »
I suggest that if a selection of files has been made that the Windows "context menu" show an option to either pack or unpack the files in the selection. Choosing either would offer the standard dialog that you get when you choose /files/pack or /files/unpack from the menu.
Thanks for the great software Altap. I regret that you didn't see fit to charge everyone for the upgrade from 2.0 to 2.5. You've taken an entirely satisfactory file manager to a completely new level. It's fast, reliable and does just about anything that can be imagined.
I will buy a new license when 2.5 is finally released. Great work you guys.
Re: Right clicking (while files selected) should offer Pack/
John wrote:I suggest that if a selection of files has been made that the Windows "context menu" show an option to either pack or unpack the files in the selection. Choosing either would offer the standard dialog that you get when you choose /files/pack or /files/unpack from the menu.
Yes, we like this idea too. In the ALTAP Roadmap we call it "Better Windows shell integration: file associations, context menus".
