Wrong file icons in the window
Posted: 18 Aug 2016, 10:29
by peschi001
Hello,
listing files in the left or right window displays the wrong icons.
In the file characteristics the icon is correct.
WBR Peter
Re: Wrong file icons in the window
Posted: 18 Aug 2016, 11:58
by SvA
Hi Peter,
please check your settings on the configuration page "Laufwerke" (Drives ?)
Sometimes refreshing the panel (Ctrl+F9) helps.
Also try to disable icon overlays in the configuration and see if that helps.
