Wrong file icons in the window
peschi001
Post by peschi001 »
Hello,
listing files in the left or right window displays the wrong icons.
In the file characteristics the icon is correct.
WBR Peter
Re: Wrong file icons in the window
Hi Peter,
please check your settings on the configuration page "Laufwerke" (Drives ?)
Sometimes refreshing the panel (Ctrl+F9) helps.
Also try to disable icon overlays in the configuration and see if that helps.
