Mention F4 opening dropdown
mdruiter
Post by mdruiter »
I just noticed one can press F4 to open a dropdown box. I usually press the (Windows standard?) Alt+Down.
Is the F4 working on purpose? If so, you might want to mention it in the shortcut section of the help file.
Or maybe I an missing something?
Edit: I just found out that F4 is also a (sort of) Windows standard. Mentioning it still wouldn't hurt.
Groente, Michel.
MartinS
Re: Mention F4 opening dropdown
Post by MartinS »
You mean pressing F4 in Windows Explorer? In AS F4 on file is for opening the asociated editor...
MartinS wrote:You mean pressing F4 in Windows Explorer? In AS F4 on file is for opening the asociated editor...
No he ment this:
Open search ALT+F7 and hit F4
The pulldown opens with the list of recent entered search criteria.
