Invert Selection Error
Basically I compare two directories... and the differences in Files and Directories are highlighted in Red.
When I do "Invert Selection" it works exactly as I want it to for FILES... But NOT for Directories...
Is there a way I can get it to work for Directories as well?
Re: Invert Selection Error
Thank you for the "Record Time" reply! That was very impressive.
There are so many things hidden away in the Configuration bit! I shall go and change it now.
"The Ctrl+Num Multiply key works with files and directories. The Num Multiply key works with files and optionally also with directories, see check box Include directories to select/unselect operations in Configuration/Panels."
