One letter folder name makes 3.06 crash when rightclick for property
altap4ever
Post by altap4ever »
Subject says it all.
(or selection for copy when there is a single letter named folder.)
Running on Win8.1 64bit.
Re: One letter folder name makes 3.06 crash when rightclick for property
I am sure, that its not a Salamander problem you describe here. It must be some shell extension you have installed.
What Tabs do you have in the file properties dialog when it opens correctly? The default ones are General, Sharing, Security, Previous versions and Customize (at least in windows 7 Pro)
Load the ShellExView x64 version from NirSoft, disable the extension and repeat the test.
Dont forget to close Salamander before you apply the changes.
