ListOfSelectedNames separtor character
ListOfSelectedNames | ListOfSelectedFullNames separator character.
It might be useful to have the ability to specify the separator used, instead of only have a space.
$(ListOfSelectedNames) or $(ListOfSelectedNames): defaults to the currently used space.
$(ListOfSelectedNames):: uses ':'
$(ListOfSelectedNames):| uses '|'
$(ListOfSelectedNames):, uses ','
$(ListOfSelectedNames):\r uses a newline
Not really pressing, as you can work around a particular needed format need by passing the $(ListOfSelectedNames) to a file, then using a preset batch file to manipulate as needed from there.
But something like that could still come in handy.
(Or a $(ListOfSelectedNames)$(CRLF)-like syntax to be more like Make File LIst...)
