Deletion of files - sometimes one is "locked"
antp
Post by antp »
I think that it started to appear with 2.52 b1, probably due to the auto-refresh (my guess) :
when I select "lots" of files (e.g. 50 or 100) and delete them with shift+delete, it often happens that for one of the files it randomly says that the file is locked and cannot be deleted. If I click "retry" it can delete the file, since it was not really locked, except maybe by itself.
So my guess would be that at a time the auto-refresh reads some file info at the exact same time as the deletion is done.
If you can't reproduce that I can try to check what amount of file and what size cause that.
It would be good to specify the file types yoiu are deleting. (file extensions).
Do you have some additional shell extensions installed?
antp
Post by antp »
I think that I had that with both small bitmap/jpeg files, and larger files like rar series of files, as those are the kind of files that I handle the most often.
For images I have XnView's extension showing preview in context menu, for rar there is WinRAR's contextual menu, but none is involved when I delete files as menu is not show.
And anyway I had these installed already in previous version of Salamander, with which I had no problem.
Re: Deletion of files - sometimes one is "locked"
antp wrote:"lots" of files (e.g. 50 or 100) and delete them with shift+delete, it often happens that for one of the files it randomly says that the file is locked and cannot be deleted
What kind of view do you have? Is it the thumbnail view?
antp
Post by antp »
No, the detailed list view.
It is probably not so easy to reproduce: I tested it, had the problem in 2 out of the 4 first tests, but then I could repeat again the paste / select all / delete without problem at least 15 times.
