Cloud Drive icons not showing in menu
rollhigh
Post by rollhigh »
Hi
Unfortunately ever since I upgraded to windows 10 RTM, I cannot see my google drive and drop box icons in the hot list menu. However, Onedrive does show up :P
Salamander V3.06 (tried 32bit and 64bit)
Latest downloaded versions of Google Drive and Dropbox as of 24/09/2015.
Tried the %appdata% fix listed in the forum but it did not work.
is there a way to fix this issue?
Re: Cloud Drive icons not showing in menu
rollhigh
Post by rollhigh »
Hi Jan
Thanks for the suggestion but I've tried that and it doesn't work.
It is also affecting Google Drive as well... :cry:
Thank you for letting us know - we will look at it.
I can reproduce problem with Google Drive. They moved configuration file %LOCALAPPDATA%\Google\Drive\sync_config.db to %LOCALAPPDATA%\Google\Drive\user_default\sync_config.db. We will fix this problem.
I'm unable to reproduce problem with Dropbox when I apply fix according to mentioned http://forum.altap.cz/viewtopic.php?f=2&t=31783.
Tested on Windows 10 Pro x86 and Altap Salamander 3.06.
rollhigh
Post by rollhigh »
Hi Jan
Thanks for looking into this, I can confirm both cloud links are working now after using both workarounds. :D
Brilliant!
stratusly
Post by stratusly »
Hi
Unfortunately ever since I upgraded to windows 10 RTM, I cannot see my google cloud drive and drop box icons in the hot list menu. However, Onedrive does show up :P
Today i upgrade my Operating system to windows 10 and i also get same problem like you. :/
You can use mentioned workaround or wait for fixed Altap Salamander 3.07.
shan08
Post by shan08 »
rollhigh wrote:Hi
Unfortunately ever since I upgraded to windows 10 RTM, I cannot see my google drive and drop box icons in the hot list menu. However, Onedrive aws vs azure does show up :P
im also getting same issue.:/
mliska@centrum.cz
Post by mliska@centrum.cz »
Dobrý den, mám Salamander 4.0, (x64), win 10. Nainstaloval jsem Google Drive. Pokud zadám Alt+F1, přesto se G.Drive v seznamu neukáže. Díky za pomoc.
mliska@centrum.cz wrote: 21 Feb 2021, 19:35 Dobrý den, mám Salamander 4.0, (x64), win 10. Nainstaloval jsem Google Drive. Pokud zadám Alt+F1, přesto se G.Drive v seznamu neukáže. Díky za pomoc.
Domnívám se, že jste si spletl část fóra. V této části fóra se mluví pouze Anglicky.
