v3.05 - x64 version - undelete plugin and Win10 Pro
dbeko
Post by dbeko »
When I try running this plugin, I get "access denied" on the drive from which I'm trying to recover files. Windows 10 Pro is blocking the plugin. Is there a fix for this please?
If I use Recuva v1.52.1086, I can access that same drive to recover the files.
Re: v3.05 - x64 version - undelete plugin and Win10 Pro
In order to run Undelete you have to run Salamander "As Administrator".
Try that & see if it makes a difference.
(Similarly, Undelete - Automatic Program Elevation.)
dbeko
Post by dbeko »
That was it, thanks.
