Tabs Alternative Plugin
darilek
Post by darilek »
Tabs Alternative Plugin is simple plugin for Altap Salamander that adds possibility to switch between 'virtual tabs'. No real tabs are added on UI, it just stores active panel path in internal list and allow switch between stored items.
Usage:
- download archive and extract it to Plugins folder
- press Ctrl+Shirt+T for add active panel path to store
- press Ctrl+Alt+T for simple management window where you can delete stored items or switch to selected item
Requirements:
- Altap Salamander 3.x
- NET Framework 4.0 (plugin is based on Managed SDK by Manison)
Window for tab select
Any comments, suggestions or bug reports are welcome :wink:
tabalt_x64.zip
(38.04 KiB) Downloaded 2375 times
tabalt_x86.zip
(36.28 KiB) Downloaded 2354 times
-=:|MaD|:=-
Re: Tabs Alternative Plugin
I haven't looked at it yet, but, salmhost.spl is x64.
Is that material on an x86 system?
And is .NET 4.0 a minimum requirement?
darilek
Post by darilek »
Hello I've updated basic description and added both versions (x86, x64)
-=:|MaD|:=-
