Create Directory - Trailing dot, oddity, bug, feature?
Create Directory - Trailing dot (.), oddity, bug, feature change?
> F7 -> R.E.M.
> Error: (123) The filename, directory name, or volume label syntax is incorrect.
Thought there might have been a change in that respect, but didn't find it.
No big deal... I understand whats going on.
SS 2.54 would create the directory, silently deleting the ".".
AS 3.06 gives you the error.
Shift+F4 -> R.E.M.
Creates a file "R.E.M" silently deleting the ".".
Re: Create Directory - Trailing dot, oddity, bug, feature?
I can confirm. I remember there was some change in this, probably in or before v3.0b1, see changelog.
changelog wrote:Create Directory: added removing of spaces from beginning and end of specified directory name.
It would be nice for file and directory creation to work the same in this regard.
Yes, it was changed in version 3.0. And yes, Shift+F4 and F7 should behave same in this respect, I'll take look at it.
Well, I have fixed this. Edit New File, Create Directory, and Quick Rename in panels and Rename in PictView plugin: it eliminates spaces at beginning and all dots and spaces at ending of new filename. This is completely new in Edit New File. Other commands have already eliminated spaces (but no dots).
