UNC - credentials not accepted in format DOMAIN\user
Arie
Post by Arie »
When I attempt to connect to a remote server drive via UNC the credentials are not accepted when I use the following syntax: domain\user.
The error I receive is: "(1326) Logon failure: unknown user name or bad password"
If I first connect with Windows Explorer (using domain\user) I can connect without a problem in Salamander.
However, if I use user@domain I am able to connect from Salamander right away.
Hi, try to download this fixed Salamander version and let us know if it works. (Installation: You should overwrite your Salamand.exe with the fixed one)
- http://forum.altap.cz/viewtopic.php?p=14345#14345 - Petr Solin's post with fixed version.
rtessier
Re: UNC - credentials not accepted in format DOMAIN\user
Post by rtessier »
Had a hard time reading through the original thread(!) but the fixed version works great for me.
Thanks,
Richard
