external file compare tool?
lallous
Post by lallous »
Hello
Maybe I overlooked it, but is it possible to use another file comparator (external tool) when two files are selected into two different or the same panels?
Thanks,
Elias
jis
Post by jis »
Definitely yes, try to search, for example this thread:
File Compare
lallous
Post by lallous »
Thanks for the reply.
I was aware of adding an external tool, but what I still lack is hotkey association. any other ideas?
jis
Post by jis »
Just press F9 and then press first letter of your new command in User Menu or use cursor keys. You can merge these two steps into one hotkey using external hotkey tool. Or click on icon on User Menu Bar.
lallous
Post by lallous »
Good idea, thanks!
Re: external file compare tool?
lallous wrote:Hello
Thanks,
Elias
Try winmerge http://winmerge.org/ (its free)
