New Salamand.exe argument -O
owilsky
Post by owilsky »
when I call salamand.exe with the new argument -O the splash screen is shown.
Is it possible not to show the splash screen when using -O ?
Thanks,
Oliver
stepand76
Re: New Salamand.exe argument -O
Post by stepand76 »
owilsky wrote:Is it possible not to show the splash screen when using -O ?
I think it isn't possible to disable it for -O parameter. You can suppress splash screen in Configuration -> Main Window -> Show splash screen at stratup, but it disables splash screen in general.
owilsky
Post by owilsky »
Thanks for your answer. Then see it as a feature request for the next beta :lol:
Oliver Kötter
lanux128
Post by lanux128 »
just curious, what is the -O argument for?
-O only one instance
use salamand.exe -? for more
