Insufficient system resources exist to complete
Posted: 03 Feb 2009, 18:24
by docfxit
Error Loading Configuration
(1450) Insufficient system resources exist to complete the requested service.
Ok is the only option.
This error comes up multiple times when I start the program and when I close the program.
Jan Rysavy edit: removed the bug report.
Re: Insufficient system resources exist to complete
Posted: 04 Feb 2009, 17:48
It looks like some problem with your Registry. Could you please try some Registry cleanup software? You can try for example
NTREGOPT.
See
another thread regarding Registry.
Posted: 09 Feb 2009, 17:59
by Guest
Jan Rysavy wrote:It looks like some problem with your Registry. Could you please try some Registry cleanup software? You can try for example
NTREGOPT.
See
I ran the registry compression with NTREGOPT. It didn't seem to work. I ran it a second time in Safe Mode and it did seem to work. I haven't had the problem since.
Thank you,
Docfxit
Posted: 09 Feb 2009, 18:17
Thank you for the information!
