Error Loading Configuration
(1450) Insufficient system resources exist to complete the requested service.
Ok is the only option.
This error comes up multiple times when I start the program and when I close the program.
Jan Rysavy edit: removed the bug report.
Re: Insufficient system resources exist to complete
It looks like some problem with your Registry. Could you please try some Registry cleanup software? You can try for example NTREGOPT.
See another thread regarding Registry.
Guest
I ran the registry compression with NTREGOPT. It didn't seem to work. I ran it a second time in Safe Mode and it did seem to work. I haven't had the problem since.Jan Rysavy wrote:It looks like some problem with your Registry. Could you please try some Registry cleanup software? You can try for example NTREGOPT.
Thank you,
Docfxit
Thank you for the information!
