FLAC Viewer Plugin
stepand76
FLAC Viewer Plugin
Post by stepand76 »
FLAC Viewer is plugin for view meta information on FLAC (Free Lossless Audio Codec) files.
Plugin is available here:
http://sites.google.com/site/stepand76/asplugins-enu
You can discuss the plugin in this thread.
Any comments, suggestions and feature requests are welcome.
stepand76
Post by stepand76 »
Version 0.2.0 (28.1.2009)
[+] Texts moved to SLG file (now it is possible to translate plugin to other languages).
[+] Added version information (VERSION_INFO) into plugin binnary files.
[+] Added plugin icon and icon of viewer window.
[-] Fixed placement of viewer window.
[-] Fixed showing of message dialogs (icon, set of buttons).
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancement
stepand76
Post by stepand76 »
Verze 0.3.0 (4.2.2009)
[+] Added compatibility with AS 2.52 beta 1.
Legend
[*] Change
[-] Bugfix
kumar
Post by kumar »
Thanks a lot for this plugin! It would be great to see picture (metadata) in viewer? Is it on roadmap?
stepand76
Post by stepand76 »
Yes, it is planned, but I'm busy last days, so I cannot estimate when it will be done.
Eric
Re: FLAC Viewer Plugin
Post by Eric »
Thanks for the plugins.
It seems, that they don't work anymore with 2.52 beta 2 (JSON and Flash neither)
even though it's noted in the release notes:
Altap Salamander 2.52 is now backward compatible with plugins for versions 2.5 and 2.51.
Thanks for any update.
stepand76
Post by stepand76 »
Version 0.4.0 (24.8.2009)
[*] Fixed compatibility with AS 2.5, 2.51 and 2.52 beta 2.
[-] Fixed Alt+Space navigation in viewer.
[*] New view style (requested by ether).
Legend
[*] Change
[-] Bugfix
Eric
Post by Eric »
Great, thank you. :P
Eric
stepand76
Post by stepand76 »
Version 0.5.0 (23.10.2009)
[+] Added the "Focus" command (F) - focuses the file in the panel.
Legend
[*] Change
[-] Bugfix
stepand76
Post by stepand76 »
Version 0.6.0 (4.3.2010)
[*] Built with Delphi 2010.
[+] Enhanced "About" window.
[+] Added an option to save possion and size of viewer's windows.
[+] Added an option to prefer keyboard shortcuts in main menu.
Legend
[*] Change
[-] Bugfix
flacviewer_0.6.0.zip
(765.83 KiB) Downloaded 3609 times
svyr
Post by svyr »
I'm getting a very strange bug with the latest version of the plugin (on any file i try to view tags for):
it looks like the delimiters aren't read correctly or something, so the tags aren't properly divided into sections for display.
I've attached a screenshot of the proper tag in aimp and what I get in 0.6.0
Flacview 0.6 - def not ok
Aimp2 screenshot (ok)
stepand76
Post by stepand76 »
svyr wrote:I'm getting a very strange bug with the latest version of the plugin (on any file i try to view tags for):
Thanks for the report. I will look on it.
stepand76
Post by stepand76 »
Version 0.6.1 (11.3.2010)
[-] Fixed reading of metadata.
Legend
[*] Change
[-] Bugfix
flacviewer_0.6.1.zip
(765.92 KiB) Downloaded 3476 times
svyr
Post by svyr »
Thank you for the quick fix ! Tested and looks to be working.
natri23
Post by natri23 »
plz update this to the latest beta
