XTree feature - supported?
PavelUSA
Post by PavelUSA »
Really, the only feature of XTree I am missing - in FAR or Total Commander - is when I can see all files of the drive (not separated by folders).
For example, right now i need to find "family tree" file - don't remember it's name or extension, just know that it's large, really large.
In XTree I could "show all files on drive c:" and then "Sort by size" - and find that file!
Can I do it in Salamander? I downloaded trial version but can not find such option...
Try ALT+F7, hit Advanced and set the size you wish...
But still using * in the search shows you all the files available.
Hitting Size column sorts the files according size.
See the result. Its easy...
PavelUSA
Post by PavelUSA »
SelfMan wrote:Try ALT+F7, hit Advanced and set the size you wish...
Thanks, I will try that
