Salamander for Vista SP1 x64?
jcgriff2
Post by jcgriff2 »
Hi. . .
Is there a 64-bit version of Salamander v2.51 > available? Or is there a way to re-re-direct Salamander to use the %windir%\sysnative folder instead of being re-directed from \\system32 to \\syswow64?
Also, when performing Vista registry searches, Salamander gets caught in the near never-ending loop found in the virtual key HKLM\software\Wow6432Node\Wow6432Node\Wow6432Node\Wow6432Node\Wow6432Node, etc... I assume this to be x64 related as well. Is there a way to set the registry search to omit this path?
Thanks.
jcgriff2
Hi, 64-bit version of Altap Salamander is not available now. We plan it as high priority task from our todo list.
jcgriff2
Post by jcgriff2 »
Thank you, Jan... looking forward to it.
JC
