The database viewer plugin shows the column numbers, but not the row numbers. Is there a way to show this?
Thanks,
Derek
Database Viewer Plugin Row Numbering
Re: Database Viewer Plugin Row Numbering
Starting with the next version of Altap Salamander (2.52), the current row number will be indicated on the toolbar.dprice wrote:The database viewer plugin shows the column numbers, but not the row numbers. Is there a way to show this?
