I already read some threads about the FTP plugin, so here my problem: downloading much small files is very slow. I downloaded my WordPress files. 7,87MB. The plugin needs 16 min 13 sec. FileZilla do the stuff in 1 min 2 sec!?
Also the plugin only uses one connection. It seems that FileZilla uses at least two connections (I'm not sure, but the queue shows two progress bars at the same time).
Logs are saved.
Greetz from germany,
Dennis
FTP plugin: download very slow
cincura.net
Re: FTP plugin: download very slow
You can use more threads for downloading in AS. Just press "Details >>" button and the use "Add" button to add more threads, that will be used for current operation (download, upload, chmod, etc.).
Jiri {x2} Cincura
Salamander's FTP Client plugin allows using multiple connections - just click on Add button (under Details >> button).FunnyDingo wrote:Also the plugin only uses one connection. It seems that FileZilla uses at least two connections (I'm not sure, but the queue shows two progress bars at the same time).
- ftp.gif (18.92 KiB) Viewed 16534 times
FunnyDingo
OK, I checked out transfer with 10 threads. Elapsed time: 1 min 36 sec.
I think I missunderstood this feature: my assumption was, that the plugin would create automaticly an specific amount of threads depending on outstandig operations and the usage of only one thread results from some problems creating more threads.
Maybe you can implement a per server option like "If there are more than X operations, create Y threads automaticly"?
Another problem with slow uploads: http://forum.altap.cz/viewtopic.php?t=2894
