Shortcut keys don't work
rgavrilov
Post by rgavrilov »
I have selected a file, then clicked right mouse button, selected "Tortoise SVN", a sub-menu popped up sub-menu item "Add" has "A" underlined, but pressing 'a' on the keyboard does not jump to the "Add" item. Shortcuts don't work for any other Tortoise SVN sub menu item.
It works as expected in Windows Explorer.
Hi, thank you for the information. I can reproduce it and we will fix this problem.
Update: fixed, will be included in AS 2.52. The keyboard handling was introduced from TortoiseSVN 1.5.0, version 1.4.x doesn't work properly.
