regexp -help with filtering results
Posted: 30 Mar 2008, 17:53
by assaf azoulay
hi! can somone help me with regexp?
i have this problem ,
i want to search for file(s) that contains word1 AND word2
that means that files that contain word1 and not word2 or:
word2 and not word1 will not be displayed in the results
how do i do that?
Posted: 30 Mar 2008, 18:04
by Ether
There's a simplier way: Search for files with word1 and then refine them by searching for files with word2.
To refine: On the right of the Find Now button, there's a small arrow, press it, and select 'Refine - Intersect with Found Items'.
Posted: 30 Mar 2008, 18:16
by Guest
hi!
thanks but it didnt work,when i press on refine ,
it looks that as search from the begining.... :(
Posted: 30 Mar 2008, 18:37
by assaf azoulay
oops now i've got it , you need to search for word1 then type word2 and
only then press ctrl+i to intersect the result with previous results
thanks! :lol:
Posted: 31 Mar 2008, 18:42
by zarevak
ether wrote:There's a simplier way: Search for files with word1 and then refine them by searching for files with word2.
I don't think using two searches is simpler then one search. At least it takes twice the time and effort. :(
I've already asked for boolean operators in word Search in Czech part of the forum: Search - logic operators in word search (Czech)
Posted: 01 Apr 2008, 07:44
by assaf azoulay
hi! thank's for the reply
i have small problem that i dont understand czech language
can you please tell me what i have to write in find dialog to search with
the logic operator 'AND'?
Posted: 02 Apr 2008, 01:54
by zarevak
assaf azoulay wrote: hi! thank's for the reply
I'm sorry for the confusion. The feature is not available in Altap Salamander (yet?). The thread is a discussion about the feature request to add such boolean operators.
As written by ether you can use Refine features in Find dialog to mimic simple boolean operations:
AND - Do a regular search (Ctrl+F) for the first word, then write the second search parameters and click "Refine - Intersect with Found Items" (Ctrl+I)
OR - Do a regular search (Ctrl+F) for the first word, then write the second search parameters and click "Append to Found Items" (Ctrl+W)
AND NOT - Do a regular search (Ctrl+F) for the first word, then write the second search parameters and click "Refine - Subtract from Found Items" (Ctrl+S)
Posted: 02 Apr 2008, 09:58
by Guest
thanks. :D
