Disconnect network shares - still open
thomas_s
Post by thomas_s »
In the last time, when I press F12 in the Altap Salamander to disconnect networks shares I always get the warning that some files are still open. A few weeks ago this was not the case. I'm not sure whether the update to 2.51 caused this issue or another software.
Do other users have always the same warning when disconnecting network shares?
My System: Vista Business 32-bit with a limited user account
Cheers,
Tom
cincura.net
Re: Disconnect network shares - still open
Post by cincura.net »
I'm using 2.51 without any problems. So I think, another SW is keeping it open. Try to use tools from Sysinternals, to find the application.
Jiri {x2} Cincura
Check the UNLOCKER http://ccollomb.free.fr/unlocker/
You can then right click on a folder and see which processes/programs hold the directory/file.
