i'd like to suggest a nice fature to be implemneted in the next version.
Everyone knows the shared directory hint when type the adres in the standart RUN command dilalog in Windows (run1.jpg)
It will be great if the same thing will be implemented for the "Change directory" dialog in Salamander (Shift+F7) (run2.jpg)
10x
Boby
Network path hints in "Change directory"
- standart windows RUN command
- run1.jpg (14.34 KiB) Viewed 7363 times
- "Change directory" dialog in Salamander
- run2.jpg (11.58 KiB) Viewed 7365 times
Re: Network path hints in "Change directory"
Yes, indeed, that will be a very nice feature!
But not only at network pathes. Like the RUN command dialogue at local pathes too.
Jan, any comment?
Wolfgang
Jan, any comment?
Wolfgang
