Zip and encrypt
KNUT
Zip and encrypt
Post by KNUT »
Hi!
Is this a bug or a feature :?:
My standard Packer ist the ZIP Plugin (Alt+F5).
But after using once the Encrypt Plugin (CTRL+SHIFT+E) the next time I want to Pack (ALT+F5) the "Encrypt Plugin" is the selected Packer :(
I know, Encryption an ZIP-Archives are both "Packer", but I dislike the behavior mentioned above.
My suggestion: CTRL+SHIFT+E does not change the selected (standard) Packer :!:
Not a bug, moving to the Feature Requests.
The Encrypt plugin is a standard packer (such as 7-ZIP, ZIP, etc.).
There is a shortcut Plugins > Encrypt & Decrypt > Encrypt because we worried that people will not find the Encrypt command under Pack dialog box.
