view html-file via linkage to said html-file
ibex
Post by ibex »
I'm not sure where to locate my (crazy) question :-(
Is it possible to use salamander i.e. its built in viewers to view a html-file by establishing a linkage to the said html-file and then double clicking this link?
Thanks for your response in advance!!
Best regards
Gerd
Internal viewers could be activated only using File > View commands (for example with the F3 key).
Unfortunately it is not possible to open viewers with double-clicking files.
