Hi There,
I would like to create a self-extracting file but I would like the contents passworded. This is because if I select the Self-Extracting exe with WinRar I can Extract the files from the Exe.
How can I encrypt the contents so that it will only self-extract when a password is entered.
Thanks for your help,
Steve Wilson.
Self Extractor
Hi Steve, it is possible to protect ZIP/SFX archive using password.
Please see
http://www.altap.cz/salam_en/help/zip/sfx_creating.htm
and "Encrypt files" section at
http://www.altap.cz/salam_en/help/zip/u ... ackdlg.htm
Please see
