Undelete Mobile Device
Guest
Post by Guest »
I can see my mobile device in Salamander but can't seem to use undelete. Please help.
I was forced to do a hard reset on my device and didn't have the full backup I thought.
I now need to scan for and restore files on the pocket pc's internal storage that can't be removed for an alternative method.
Thank you
James
Hi James, the Undelete plugin works only with logical drives or images. Could you map your device internal storage so it is accessible as Windows drive (for example D:\ or E:\)?
Guest
Can't Map a Mobile Device
Post by Guest »
Can't seem to map a mobile a pocket pc's folders.
