Is A Way To Change The Size Of Detailed/Brief View Icons?
knightball
Post by knightball »
Is there anyway to change the size (increase) of the icons in Detailed/Brief Views. They do increase in size if you increase the Panel Font Size. But, i would like to keep my font size but have the icons be bigger.
Anyone know how to do this or if it can be done at all?
TIA
knightball
Unfortunately it is not possible.
