Tortoise SVN icon overlays not showing
lbolognini
Post by lbolognini »
Hi there,
both on Win2k3 Standard Edition an XP Pro SP2 i can't see any icons overlays.
I'm using Tortoise SVN 1.4.5
I've killed the TSVNCache process but nothing changed.
Thanks,
Lorenzo
lbolognini
Problem found, my bad, i had the
"Show overlays only in Windows Explorer" setting activated.
Which i activated for SVN performance reasons.
Would be nice to have it working with that setting on.
Thanks,
L.
lbolognini wrote:Would be nice to have it working with that setting on.
The running process is checked against the "%SystemRoot%\explorer.exe" path in TortoiseShell\TortoiseStub.c. No chance for Salamander and other file managers.
