Default Batch Renamer(Renamer) Plugin Settings/Check Boxes
Posted: 07 Nov 2007, 01:20
by knightball
When I use the Plugin Batch Rename (Ctrl+Shift+R), the dialog box always comes up with the following check boxes checked:
Case sensitive
Only once in each name
I would like the above two boxes to be unchecked and the following boxes checked each time I open the renamer:
Regular Expression
Exclude Extension
Summary: I want the above two boxes checked and everything else unchecked.
Is there any .ini file or other file I can use to modify this plugin dialog box.
Please Help. TIA.
knightball
Posted: 07 Nov 2007, 02:28
Enough would be that the checkboxes retain the "last used" state.
Posted: 07 Nov 2007, 03:46
by knightball
Is that possible?
Posted: 07 Nov 2007, 23:42
by th.
You can recall the last settings with Ctrl+L (Options -> Last Used).
Posted: 08 Nov 2007, 15:24
by knightball
Great!!!! Thanks alot!
