Playing with Salamander: ROT13
Uryyb folks!
I was just playing with Salamander and small useless tool came from it: ROT13 encryption. It is a "charset" conversion table for Internal Viewer and for Conversion tool. From now on, you can encrypt any of your text files in Salamander 8)
Installation instructions:
1) Download and unzip the TAB file into appropriate C:\Program Files\Altap Salamander 2.5\convert subdirectory (depends on your system settings)
2) using Notepad edit convert.cfg file in the same subdirectory and add these lines at the end of the file
ROT13=ROT13.TAB
3) restart SalamanderNotice: I do not take any responsibility when your wife decrypts love letters for your lover. If you need to encrypt any sensitive information, use Encrypt & Decrypt plugin or any other software.
rot13.zip
rot13 table for Salamander character conversion feature
(372 Bytes) Downloaded 698 times
