It seems that the Eroiica viewer is no longer working on my system. I am running AS 2.5 on WinXP SP2. I've attached a zip file of the screenshots when I test the plugins. Do you need me to send a bug report?
Thanks,
Derek
Eroiica Viewer WMF Filter Export Failure
- AS-Eroiica_Errors.zip
- (54 KiB) Downloaded 732 times
Re: Eroiica Viewer WMF Filter Export Failure
Derek, did you change something on your system recently? Like changed (restricted) access rights to registry? Or installed some software?dprice wrote:It seems that the Eroiica viewer is no longer working on my system. I am running AS 2.5 on WinXP SP2. I've attached a zip file of the screenshots when I test the plugins. Do you need me to send a bug report?
Yes, please, send me bug reports (to support[at sign]pictview.com]) *before* and *after* the error in AS_Eroiica_Error2.png is displayed.
Ideally:
1) start AS
2) create a bug report
3) try to view any DOC or PDF file , or other document supported by EV, to get AS_Eroiica_Error2.png
4) create 2nd bug report.
Thanks!
-- Jan
