Copying/moving files on the other side
lbolognini
Post by lbolognini »
Hi all,
I'm suprised i haven't found a shortcut for such a common operation as copying/moving a file from side A to side B
I would expect just to hit the left or right arrow to copy the file and maybe shift + arrow to move it
Wouldn't that be neat? ;-)
L.
Hadez
Post by Hadez »
Hi, you can use F5 for copying and F6 for moving files/directories.
And I think that using arrows is problematic, because they are reserved for Brief viewing mode.
Re: Copying/moving files on the other side
lbolognini wrote:I'm suprised i haven't found a shortcut for such a common operation as copying/moving a file from side A to side B
Please look at Altap Salamander Help, sections Window Components and Using Altap Salamander.
Example: Copying Files and Directories.
